How To Use Cruise Control 2002 Rav4?
Salvo213
Hi Guys
i have a 2002 toyota rav4 and it has cruise control. There is a knob which is located to the right of the steering wheel and while im driving, i have turned this knob and nothing happens. Any ideas???????
My car is a 2006 but I would think the control will work the same .....
To arm the cruise You push the button on the end of the cruise arm.
This should light up a symbol on the dash to inform You that the cruise is ready or armed if You like.
To set the cruise press the arm downwards
Once set pressing down and holding will decrease the speed
Pressing upwards and holding will increase the speed.
using either the clutch or brake pedal will cancel the cruise but still leave it armed
To resume Your last set speed flick the arm upwards and the vehicle will resume its last set speed
When You turn the ignition off the cruise will switch off or disarm so will need arming again before using again...
HTH.
Wee Charlie.
To switch on my cruise control, I open the passenger door and let the other half in. :rolleyes::rolleyes::yahoo::yahoo:
Del
Not sure if you are aware Charlie but on the 4.3 it can also be cancelled, but left 'armed', by flicking the stalk towards the wheel. Really useful if you want to loose some speed but don't need to brake. Had mine ages before I discovered that :wacko:
Del
Have you noticed that, on an aircraft, the Captain always sits in the left hand seat...................
No Mate to be honest I did not realise that !! Cheers !!
Wee Charlie.
I tried that, but it seems to cause an awful whining sound.... :rolleyes:
Strange that,I get the same too,and it seems to somehow affect the radio and heater setting as well. :thumbsup:
Del
That thumb wheel on the dash is the dash panel dimmer switch.
The cruise control is on a stalk.
