Bank 2 Sensor 1 Circuit Fuse
786innovation
My car is 2001 plate toyota avensis 1.8 vvti GS.
Which one is the fuse for Bank 2 Sensor 1 circuit? Engine management light is due to the code p0155 o2 sensor heater circuit malfunction (bank2 sensor1. I came across a video on Youtube that it is not always due to the bad sensor, but instead can be caused by fuse. the link is
Please help me to locate this fuse so that I could check it before changing the oxygen sensor. Thanks, Regards
So no body knows.. which & where are the fuses for oxygen sensors... If any body had the clue then please share... It will be great favor. Cheers,
Well, I suppose you could check them all.
Shouldn't take more than 10 minutes.
