Fit A Reverseing Camera
maurice07
hi, can anyone tell me how to remove the plastic trim from around the inside of the tailgate on my auris 07 plate d4d 5 dr please, the reason being i need to route a wire from a camera near number plate lights to behind the reverseing light,any advice please. thnks
The trunk door consists of 4 plastic pieces. The top, the right/left and the big plastic tha covers the main compartment.
Top Piece
It is the plastic located under the center top tailight. You just pull it with your hands.
Right/Left
Here it is a bit tricky.
You have to remove the 2 plastic "things" that are holding the tray by the little ropes.
Those things are made by 2 pieces and they are "sandwiched" together. (You will probably need a knife or a screwdriver to seperate the two pieces)
Get the top part of them out.
After that you can pull the two pieces.
In my case they didn't seperate from the main piece at once.
Main Piece
First you remove the piece that is right behind the license plate. The one that has a fit for a screwdriver.
Then you have to remove the handle right next to the latch. You push in the four corners with a screwdriver and pull till you get it out.
Finally, all you have to do is pull the main cover. There are no screws, just plastic pins holding it to the trunk. Just be careful not to pull too hard and break any plastic.
Not that it breaks easily.
:thumbsup: I hope i helped you :thumbsup:
I will be able to upload photos by Friday if you want.
If more people want it, i can make a tutorial on how to install a rearview cam with a monitor. ;)
Top Piece
Right/Left
Main Piece
hi takumi, apologies for late reply been out of country, great info will give it a go this w/end
