Wheel Bearing
SidBurns
Afternoon all,
Front Right Wheel Bearing away, well I'm 99% sure it's the WB, which Toyota quoted over £400 to source and fit! I (think) have found the part I need online:-
http://www.eurocarparts.com/ecp/c/Toyota_Rav-4_2.0_2002/p/car-parts/car-transmission/transmission-parts/wheel-bearing-and-wheel-hub/?628820920&1&4791ff016302d38e383a4f970b860de0074ed6dd&000370
Is this the correct part?
Thanks very much in advance oh and do/would I need anything else?
Cheers,
Sid.
I'd check the hub once the bits are removed just in case there's any damage to it.
Before parting with any cash at all, I'd check your tyres. Sometimes they wear badly and can form flat spots, the sounds from these sound exactly like a dodgy bearing. Swap the wheels side to side or front to back and see if the sound moves with them.
