Need Another Key/fob For My Rav4 2011
antonsev
hi
i'm new here and i need to buy a Denso 1512V spare key for my Rav4 2001.
even a second hand would be ok since i read that i can re-program it and cut a new blade for it.
anyone can guide me please?
tks
tony
hi
tks
tony
Hello Tony,I know you will be welcome in THE CLUB :thumbsup::thumbsup:
If a search is done there is plenty of info re keys on site.
I bought my last key from a certain shoe repairers on the high st beginning with "T"
I took my key in and they were able to copy the chip in it.
That I think was just for the imobiliser
Hope this helps
Del
hello crofter
i just bought one off eBay for 30 quid
will hope to find hopw to program it now
keep you posted
a
Hello
Is this the correct procedure to program a DENSO 2 key FOB-Key 1512V with CR1616 Battery for RAV4 2001??
I found it here: http://www.outlawjapclub.co.uk/forum/showthread.php?t=5857&page=4
Any help appreciated
Tks
Anton
TO LOCK/UNLOCK CAR PROGRAMMING
open drivers side door and remove key from ignition switch
insert key to be programmed into ignition switch then remove it
Within 40 seconds
1. Press lock and unlock on the vehicle door control switch at 1 second intervals 5 times
2. Close and reopen drivers door
Within 40 seconds
2. Insert key into ignition switch
3.Switch ignition ON and OFF once to program new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes.
4. Remove key from ignition switch.
System should now lock and unlock car once or twice depending which mode has been selected
Within 40 seconds
1.Simultaneously press and hold key lock and unlock buttons for a maximum of 1.5 seconds.
2.Within 3 seconds press any key button for a minimum of 1 second.
Note:if system locks and unlocks car twice,programming procedure has not been completed.Repeat programming procedure
TO PROGRAM IMMOBILIZER
Insert programmed black key into ignition switch
Within 15 seconds
1. Press and release accelerator pedal 5 times
Within 20 seconds
1. Press and release brake pedal 6 times
2. Remove black key
Within 10 seconds
Insert black key to be programmed into ignition switch
Within 10 seconds
Press and release accelerator pedal once. Immobilizer warning light will flash
After 1 minute Immobilizer warning light will extinquish.
To exit programming mode:remove ignition key and press brake pedal atleast once with 10 seconds or wait 10 seconds
Is it possible that no one knows?? :unsure:
My RAV4 has a TVSS-4D like others of the same X51reg in UK.
Any help appreciated.
Cheers :help:
Cheers :help:
Have you tried it yet? It'll either work or not I guess............. :unsure:
yes you're right .... you're guessing, so it could be that i finish off without having any key working!! :!Removed!:
i have been around in the forum nearly all day yesterday to find some help and advice, however all the 'helpers' are reluctant to divulge such information, it seems :blink:
strange, but, everyone likes a commission in his pocket every now and then and it's a pity most forums these days are being used in such a way rather than to genuinely help people.... :wacko:
will keep posting the outcome when i have the 2nd hand key in my hands :yes:
still hoping for some direction from a genuine expert here :help:
cheers :D
cheers :D
Try a search on this forum.
I found this that may well help you:
LINK
thanks davrav
looks like it is the same procedure i found for the immo
will have a go to it when the key arrives
i also found this which looks to be what i need and similar to my previous instructions found elsewhere
http://www.honestjohn.co.uk/forum/post/index.htm?t=67444
will keep you posted
i still cannot understand how no expert turned up to help on such a simple matter. strange from a toyota dedicated forum :yawn:
thanks davrav
Could be due to security issues,or peeps dont consider,although there are some very knowledgable members,they are not "experts" mmm?? and do not wish to put themselves forward as such!
Just MY opinion,of course
Del
hi
tks
tony
Hope this helps
Del
Toolworths ?? Tarks and Spencer ? Turrys ??...................... Timpsons ?? Nah that cant be right ..........
Wee Charlie.
actually the problem looks like being always the door lock/unlock function, not the immobiliser.
i'm still waiting for my eBay ordered key .... tiktoktiktoktiktok :blink:
When I had my Mk1 RAV it had a separate fob to activate the locks.
I bought a spare fob from fleabay and I think progamming it invovled removing a panel by the pedals on the trans tunnel and gaining access to a control unit and establising a link to between the fob and unit.
I'm a little hazy on this and it may not apply to the later models with the key/fob combi.
Perhaps someone can clarify this?
If it helps I have this on paper (somewhere) and will forward this to you if someone can confirm it applies.
Del
Guys I managed!! :yahoo:
For both procedures, I didn't get them right the first time. As for the keyless entry programming following the steps once didn't program my 'new' key, but by repeating the procedure and pressing the keys in nor order finally got it programmed :toast:
My RAV4 is a UK 4.2 Year 2001. These are the factory details 09/2001 TOYOTA RAV4 (ZCA25R-AZMNKW)EUR RHD 1ZZFE MTM
Here are the full instructions :thumbsup:
THE KEY YOU NEED TO BUY OFF eBay OR FROM A SALVAGE
Toyota Remote Key Fob 2 Button DENSO 1512V Blank Blade
Refurbished Toyota Remote Key with an Uncut Key Blade bought off ebay;
Condition: Used in Good Condition; Tested;
Part Number: DENSO 1512V;
Frequency: 433.92MHz;
Key Shell Type: 2 Button - Aftermarket Product;
Battery Type: CR1616;
Transponder Chip: YES;
Key Blade: Blank / Uncut - Denso Type;
Circuit Board Identification: H mark on Case;
Please Note: Picture Displays Remote whit Cut Key Blade for Easer Identification.
Programmming Immobiliser signal on this 'new' spare key:
To stop the process at any time, press on the foot-brake pedal 1 time.
1. Simultaneously press and release the foot-brake and accelerator pedals 1 time.
2. Insert existing master key into ignition. Leave the key in the OFF (LOCK) position.
3. Within 15 seconds of inserting the key, press and release the accelerator pedal 5 times.
4. Within 20 seconds, press and release the brake pedal 6 times and remove the key.
5. Within 10 seconds, insert the new key into the ignition.
6. Within 10 seconds, press and release the accelerator pedal 1 time.
7. After 80 seconds the new key is registered and the security light will go off.
8. Remove new key and press and release the foot-brake pedal 1 time.
9. The new key will now start the vehicle.
To Program Wireless Transmitter for Keyless Entry:
1. Begin with:
_ The driver’s door open and unlocked.
_ Key out of the ignition.
2. Insert and remove the key from the ignition switch 2 times within 5 seconds.
3. Close and open driver’s door TWICE within 40 seconds.
4. Insert the key into the ignition and remove it.
5. Close and open the driver’s door twice within 40 seconds.
6. Insert the key into the ignition.
7. Close the door.
8. Turn the ignition switch from “Lock” to “On” and back to “Lock” at about 1 second
intervals to select the desired mode:
_ 1 time for ADD mode.
_ 2 times for REWRITE mode.
_ 3 times for CONFIRMATION mode.
_ 5 times for PROHIBITION mode.
9. Remove the key from the ignition.
10. To confirm your mode selection, the power locks will now cycle “lock” to “unlock” a
number of times corresponding to your key cycles in step 8.
NOTE:
If Confirmation or Prohibition modes have been selected, opening the door will
complete the procedure.
11. For Add or Rewrite modes, within 40 seconds of Door Lock confirmation...
A. Press both transmitter Lock and Unlock buttons simultaneously between 1 and
1.5 seconds and release.
B. Within 3 seconds of step A, press the transmitter Lock button for more than 1
second and release.
C. If the transmitter has been successfully programmed, the power locks will cycle
“lock” to “unlock” once at this time. If there are problems with the transmitter or
the procedure up to this point, the locks will cycle twice. If this occurs, verify that
you have received the correct transmitter, and then repeat the above procedure.
D. If multiple remotes are to be reprogrammed, repeat steps A–C.
12. Open the Driver’s Door.
Glad you got it sorted Anton.
A bit of a wait and a lot of fiddling around but waaaaaaaaaaaaaaaaaaay cheaper than going to a dealer :thumbsup:
