Condensation In Headlamps?
budgy
Hello everyone,
I very much the newbie around here, so hope I'm welcome :rolleyes:
My Celica has gathered some condensation in the headlamps, what could be causing this problem?
Apologies if this has already been asked.
Budgy
Make sure the rubber boots that go around the dipped & main beam are completely on properly. If they are and all the other bulbs are in properly, then the main seal of the headlight must have failed somewhere.
  • 5 months later...
Assuming it's a Gen7 you could try removing the unit and dry it out in an airing cupboard.
When you refit make sure you replace the bulb covers (as mentioned above)
