Corolla Verso 2006 Won't Downshift
Renaldas
Hello to all.
I have Corolla Verso '06 reg. T180 manual transmission. And recently I have noticed (It was Ok before), that when down-shifting let's say from 6th to 4th or 3rd it is very difficult to get the gear in. I like down-shifting a lot when braking, and I can't get into lower gear. I can get into lower gear when the car adequately slow downs. Up-shifting is normal. Sorry for my English, but I know there some kind of synchronizer (could be called differently in English) which is used to down-shift the gear. Has anyone had the same issue? Will it be costly? Thank you for any response.
Renaldas
I didn't encountered that problem,But I guess that is really too much expensive,Maybe you must first consult to know the real problem.
