Fault Code P1226
thatch
Hi
I have a 2002 avensis d4d with 200k on the clock. This last week it brought on the engine management light. When ever i pull away in first or second the car looses power and the light comes on it wont go over 1000 revs. Once i switch it off for a minute and back on the light is out and the car is fine again. Im a taxi driver and on a 12 hr shift today it did it 6 times. I put it on a computer and it came up fault code p1226 fuel line malfunction. I changed the fuel filter but it made no differnce. The car is driving perfect in every other way and not smoky. Any one any ideas.
Thanks...
Paddy
clean scv
Hi is that a DIY job or experience needed?
Just to update i took the gauze out of the fuel tank and cleaned it and problem still there. Mechanic thinks either scv valves on fuel pump or injectors themselves. So getting injectors tested on tuesday!
clean scv
Dont Not yet.
On the fuel pump, Green and Red connectors,
These are the SCV.
Remove - clean with brake disc cleaner (blow through the hole)
reassemble and report back.
clean scv
Dont Not yet.
These are the SCV.
Thanks for that i hear they can give a bit of trouble.
I decided to take out the injectors and get them tested. And it turns out that one of them was bad. Not holidng or producing the correct pressure. Phoned toyota quoted £355 for ONE new injector...i knew they were expensive but thats crazy! Anyway i got a used one from a local car breaker for £50 got it tested and put it in the car. Everything is fine again...thankfully!
Thanks all for any help...
