Just need a few quick questions answering please!
Can someone confirm the Speakers under the windscreen are 10cm? Is depth an issue here and will the little tweeters in the a pillars work with aftermarket Speakers?
Also, what size are the Speakers behind the grills in the 3dr rear side cards? Again, depth also?!
Thanks in advance :)
Can't help you on the depthe. undr the windscreen are 10cm, if you have them in the rear under the windows then they're 10cm too.
The tweeters in the A-pillars WILL work with after market Speakers, however, if you fit 2-way (or more) coaxials you'll get too much
"high" since they allready have tweeters in them too. In that case it would be best to disconnect the pillar-tweeters.
