1997 Rav 4
Tester
Hi helpers. Can anyone help please? I was observing that front hub looked quite easy to remove from car and slip away from CV spline BUT
I got a bit scared about disconnecting a line connected to the hub centre which I presume is something to do with the ABS system!
I am wondering if this is trouble for me if I interfere with this so I can remove hub? What will happen??
It would help if you said why you are removing it. The info on stripping the hub is contained in the tech info pinned at the top of the RAV section;
http://www.toyotaownersclub.com/forums/index.php?showtopic=71649
Often, the sensor swells inside the hub and will not come out but you should be able to disconnect the inner end and leave it installed while you work on the hub.
