Installing A Handsfree
tcawley
hi,
i installed a nokia ck7w hands free in my 2000 toyota yaris. my problem is that the ignition line behind the radio does not seem to work with my hands free (i tapped into this wire). the handsfree does not turn off and on like it should when i turn the key. i do not think the in line fuse is the problem however i will try a different fuse later and let ye know. if this wire is inactive what ignition line can i tap into ie cigarette lighter. i dont want to take apart the dash as i am not lucky with these jobs. i am willing to take out the radio to tap into wires if i have to though.
p.s i can manually turn on the handsfree
ok so i took out the cd player and changed the in line fuse and the handsfree is working properly again.
