i have a h`91 corolla gti with 120k on the clock, it has started to smoke (blue)
is it piston rings? if so can it be rebored and is it expensive?
valve stem oil seals?
i would appreciate any help thanks
jay :help::help::help:
jay :help:  :help:  :help:
hello hello... your´s corolla engine needs new pistonrings and new valve steams
oil seals... but if it smokes only when you start engine then you have to
change valve steams oil seals... i have over 10 years of ALL of corollas
engines and i know what i write to you... (i´m from finland and i have veryvery
poor english language:) ... it´s necessary to repair your engine becouse it blows
if you not do anything... broken pistonrings doing WERY BAD damage!!!!
in finland pistonrings cost (4a-g engine) 35-60 euros... and valve steam oil seals
10-30euros... new piston (stock size 81mm) cost 20-100euros per one piston.
gaskets 30-80euros. that´s not expensive... isn´t it????
but try repair your engine and keep it good condition... i can send ALL technical(finland) data if you need it.... email mikkopiironen@jippii.fi
by mikko piironen (from finland)
ps: here something in finnish language
corolla on paras!!!!!= corolla is best!!!!
tosi liukasta tietä. ei hallittavuutta!!! =wery slippery road. no handling!!!
ota kiinni jos saat!!!= catch if you can!!!
ooppelit haisee!!!!= opel´s/vauxhall´s sucks!!!!!
ford on ruosteen kemiallinen merkki!!!!=ford is rust chemical mark...
thanks i would appreciate the info.
jay
