hi folks.for about just under a year now the milometer has stopped working.hasnt really bothered me upto now but tried to fix it by removing the clocks and having a look.when i replaced them i found rev counter had stopped working aswell as some bulbs by the rev counter.if anyones got any advice it would be well appreciated.thanks.
As you had the clocks out, you must have not put the plugs back on properly. Check that all plugs are pressed in all the way. Can't remember how many plugs are behind the clocks, check them all.
