Hello all. I have a 2000 AE104 L Touring Corolla wagon. On the display there is a series of lights which show the gear the car is in. One of these bulbs appears to be blown. Does anyone know how to replace this bulb?
First, remove the two screws at the top of the black gauge bezel. Then, gently pry at the bezel on the lower edges about halfway out on each side to release the clips and pull the bezel out. Then, remove each of the 4 screws at the corners of the gauge cluster. Then, pull the cluster out as far as you can, and unplug the harnesses from the back. You needn't worry about mixing them up, because they won't fit in anything but the right slot. To replace the bulb, just twist the bulb holder counterclockwise and pull straight out. the bulb will pull straight out. If I am not mistaken, the bulb is a W1.2W.
Thanks dude...
