Front Seat Belt Replacement
Tay
Hi all,
I think I'm going to need to have the drivers seat belt replaced on my 03 avensis after my dog chewed it badly enough to cause some damage to it.
Does anyone know how hard/expensive thus is likely to be?
Cheers
Hi all,
Cheers
Buy one from scrappers
Disconnect Battery
leave 30 mins.
undo trim
remove seat
undo bolts and wiring
and reverse the order above
Thanks very much!
Will I need any special tools to remove seat and seat belt fixtures?
Nope
a decent socket set
and some tin flat blade screw drivers.
The seat belts are held in by a bracket and 1 bolt
you might have to remove the seat to make life easier.
Disconnect Battery and leave car to discharge as faliure to do this will make your air bags explode
