Gear Stick Noise
Weta
Sounds like a bit of resonance maybe. The engine revs at a certain level are amplified as they match the sticks natural frequency. Could try a different gear knob to change the weight thus change the natural frequency, Otherwise ensure everything in that area is nice and tight?
I don't know anything specific mechanically but that's a likely physics answer for you!
If it's vibrating it's a well known fault. (I had it on my first Rav) It's caused by the gear shift cables vibrating aginst the gearbox or bodywork ?
There is a fix for it, try using the search function for other threads.You should find that if you put a little bit of side pressure on the gearstick
with your hand the noise should disappear.
63mph elbow starts to itch
...it's called Whitefinger of the elbow...ah was once a lumberjack..aye, right
Fibber Kev :shutit:
