Engine Whine When Throttle Released 2.0 D4D
Hardtack
When I change gear and step off the throttle pedal the engine makes a high pitched whine type noise for a moment as the revs reduce. Is this normal? Turbo noise perhaps? Never had it on other diesels.
Just spotted Speedemon's post and replies. Sounds like same query as mine. Guess all is ok then. Thanks all.
i noticed mine doing that ages ago and as i've done 128k in less than 3 years i wouldn't worry,it's weird and intermittent but harmless
If it's a very high pitched whine then it could be the gearbox bearings making the noise. Don't think it's an issue unless it gets worse. My petrol Avensis does it too.
