Bird Poo!
roger_37
hi peeps, looking for a bit of help.
how best to remove bird poo,that washing wont budge
any help?
any help?
Get it off one way or another asap, it can etch through your paintwork pretty quick.
Soak it well with shampoo/water and some kitchen roll.
washing wont budge it.
it has marked the paintwork.
what can remove it?
A good soaking, kitchen roll and gentle application of a fingernail. Use loads of water!
Soak, soak and soak it again :yes:
Give it time and the vile stuff will soften and then can be washed off but I bet it has damaged the clear coat of your paint :angry:
yes i think it has.
what can i do,would g3 compound help?
A little biological washing detergent disolved in hot water. Use a piece of kitchen roll and hold it against the poo mark. Keep repeating for around 5 or 6 times.The enzymes in the detergent will break down the residue of the dive bomb.
Also you could try some clear vinegar - water solution. Bird poo tends to be mainly alkaline whereas vinegar is acidic.
yes i think it has.
Nothing helped when bird ******* ate through the clearcoat on the wifes Astra Rodger, cutting compound diminished it slightly thats all. :censor:
there must be some thing i can do.
well apart from a respray.
ty dervdave
ty dervdave
Best of luck :thumbsup:
t cut
tried that, no good. ty
diffrent types of t cutwhich one have you used?
i dont know which type of t cut,
it was a guy at washing station used it.
roger
Best results I have ever seen with a bird poo mark is with a cutting compound applied with an electric rotary pad. Has to be done by someone skilled, its mighty easy to go right through the layers....
Removing dried on poo I end up squirting it until covered with a white layer of pledge (other furniture polishes are availalble :) ), and leaving it for a few minutes. Then it wipes of easy.
How or if this works i not got a clue, but i am told that washing soda will shift it, idealy what you need to do is make a ring with a damp cloth around the bird poo fill the ring with luke warm water and put a few soda crystals in the water leave it for five minutes then wipe away then polish/buff the area.
As i say not used this method myself so i would do a test area first, but its suppose to work, sounds a bit harsh to myself to remove stubborn bird poo.
