Auris Rear Lens Replacement
seanels
  • 6 months later...
Hi - I have the same problem - did you ever find instructions on how to remove the rear lens cover ? thanks Mike
it's quiet easy, well it will be for me next time,
i hope you have nimble fingers, you will need a flexible extension and a 10 or 8 mm socket, after removing the bulb holder/loom out of the way, there is a nut above and below the hole (pointing forwards), possibly there is a third nut on the side panel (cant remember)
the light unit pulls off rearwards, the side part of the light unit slides off and on a blind stud
hope this helps
