Ecb -Permanent Removal Of Angle Speed Sensor?
avensis_toyota
In so far as my knowledge is not wrong, this sensor is part of the ECB, which automatically blocks the brakes, if the location of the vehicle on the road driving is losing the right direction.
I wonder whether you can simply remove the sensor, ABS and VSC will operate normally or not, given that all these systems are interconnected? ABS and VSC must continue to function normally, the ECB system is not needed. Will then be dashboard control light always on or can I turn it off, using a computer tester or something?
Please, I need answer on my question, those who want to give a lesson of safety and all good electronics properties please do not bother. No offense.
Thank you
Thank you
Hello mate, maybe this .pdf diagram will help you out, it contains a lot of information on the electronic system circuits
Regards Pete
EPS SYSTEM CIRCUITS.pdf
