Hi All :d
ep82_girl
Hi all :D
my name is Jo and i own a Mk 1 Starlet GT Turbo called Oky :) owned her for nearly 4 yrs now and all work has been done by me (well mechanics and good mates lol) car was in hell of a mess, standard and off to scrap yeard when i rescued her.
Hope you like :D
Below is my spec list and some pics:
* 75mm weisco pistons
* oil cooler
* scat rods+arp studs
* full balanced and blue printed bottom end
* chemically cleaned head and new valves
* oil cooler
* ported and polished with three angle valve job
* cruise valve springs
* 5e Kent reprofilled cams
* powerenterprise Kevlar timing belt
* light weight cank pulley
* cruise 1.8mm head gasket
* 330cc sard injectors
* td12 turbo
* 38mm tial external wastegate
* screamer pipe
* down pipe
* custom short pipe
* blitz fmic
* Ricky@racetech mani
* polished fuel rail
* polished inlet mani
* greddy emanage mapped to 1 bar low 1.3 bar high
* civic radiator and slim line fan
* apexi air filter and relocation kit
* air con removed
* full through stainless steel exhaust system
* tuning developments 255 upgraded fuel pump
* sard fuel pressure reg and gague
* sard thermostat
* greddy sandwich plate
* greddy type s bov
* clear cam belt cover
* ngk Iridium spark plugs
* act paddle clutch
* bc racing coilovers
* whiteline rear arb
* whiteline front arb
* whiteline anti lift kit
* cusco front lower arm
* hel braided brake lines
* levin 2 pot calipers+grooves discs+yellow stuff pads
* quaife LSD
* auto gague-water temp
* auto gague- oil pressure
* blitz boost controller
* hks turbo timer
got to admit that's one sexy starlet
oh welcome to toc
oh welcome to toc
Thanks hunni :)
thank you both for the welcome xxx
Hi Joanne,
Welcome to the TOC, Oky looks pure quality, very nice indeed, glad someone else on here names there car, as I was starting to worry (Connie is her name) :thumbsup:
hahaha yeah my baby is named and has a blanket on in the garage in the winter :-/ lol
thanks for the welcome and hi to Connie off Oky :-)
xxx
