Avensis Gearbox - Whihc Ones?
moses19.10
Hi all,
Looks like the gearbox has failed on my 2001 1.6 GLS Avensis, what gearbox will fit on? i.e. the one from the 1.8 / 2.0 etc?
Going to be looking for a reclaimed one so obviously want as many options as I can
Cheers
If yours is the 1.8VVTI, then you can also use the gearbox from the celica 1.8VVTI.
early models were 5 speed, but the later 1.8VVTI also came with a 6 speed box.
I know which one I would go for if I was you ;)
The 1.8VVTI Celica's came with exactly the same engine and gearbox as your Avensis.
Moses,
I would rather stick with an original 5 speed gearbox for your car. I may be wrong but, I heard that it may be classed as a modification by insurance if you fit the 6 speed. Just check to be sure.
It has been done before and if I remember correctly, the 6 speed ratios are closer to each other but 6th is slightly higher than 5th of a 5 speed 'box. Also does your 1.6 have the torque to pull the longer gear? You will be changing down on every motorway incline and to accelerate.
I think 1.8 is the same as your 1.6 gearbox.
Hi all,
Cheers
hi model engine 3zz-fe? I have gearbox for avensis t22 1.6 3zz-fe.
