Avensis D4-D Starting Problem
Iansails
I have an X reg Avensis D4-D with about 140k on the clock. It runs really well but is a pig to start when it is left for more than a couple of days. The longer it's left, the worse it is. Any suggestions please?
Sounds like air could be getting into the fuel system.
I agree its possible, but I can't see any leaks.
hi mate
you ve personaly replied:
- starting battery;
- electricity leak thru charging relay or via glow plugs positive (+) strip or to the body;
- issue with Battery (what is an age ?)
check and revert
cheers/Igor
