Problem With My Water Level
m_10
Hi everyone. im getting a problem with the amount of water my car is using. i fill my water tank with the level full. after i have drive for around 1 hour, the level water goes to low level. there is any indication that the engine is heating or any thing else.. please tell me what should i do?? i thought it was the radiator cap but i changed it, its the same problem.. plz help me out.. thank you in advance
plz reply me
Petrol Avensis....Diesel Avensis....2.2 T180.....?????? :unsure:
thnk for having reply me.. where do you think is the problem??
Hello,
there is a strong possibility that you may have a head gasket problem so take it to your nearest Toyota dealers ASAP, you should be covered by their extended warranty, the details and conditions of that warranty will be explained to you by them but tell them you have been told that one exists.
Regards Pete.
heh really thanks for the reply.. will try to see if this is the real problem. will get you up to date if its ok
Heh pete, but where did all that water gone?? in less than 2 hours. did you experience any such problem with your car??
best regards MAN
in fact the water is losing by the pipe which is found near the cap where excess water goes....
Sound like the head gasket, the pressure normally created inside the engine is leaking into the cooling system and forcing the water out through the pressure cap on the reservoir and out of the tube you mention, you may find pinky colour spots on top of the engine cover, that will be the antifreeze/water mix if there is any left in the system, just depends how many times and for how ling you have been topping it up.
Pete.
Pete.
my opinion--either head gasket or cooling fan/temp sensor or air suction into an expansion plastic tank due to poor gasket. the less pressure inside the cooling system the fast boiling + leak thru over flow tube. cheers/Igor
Pete.
thanks you all.. very nice from you.. will let you know what was the problem and if it can be fixed..
