4A-Ge Small Port Hi-Torque Engine For Sale
KPARRIS-JONES
I have a Toyota Twin Cam 4A-GE for sale.
It is out of a 1991 AE92 GTi-16 Corolla and runs perfectly. It is known as the Small Port, Hi-Torque and Non-TVIS engine. It specifically has the 42mm Crank Journals as opposed to the TVIS Engines 40mm, ideal for the extra strength.
The Engine and Gearbox work perfectly, there are no rattles, taps, knocks or grinding noises etc. It is tight as a drum and pulls hard and smooth right through the rev range.
Included in The Purchase Are:
*Full 4A-GE Engine With All Ancillaries (PAS Pump, Water Pump, Alternator, Belts, Injectors - Absolutely everything the engine needs to run)
*C52 5 Speed Manual Gearbox And Drive-Shafts - These came standard with the car and have no issues whatsoever. The Clutch however could do with inspection and possibly replacement.
*Full Wiring Harness and ECU - Both standard with this car and engine, everything works and hasn't yet been removed from the car.
*Exhaust Manifold And Down-Pipe (You are NOT buying the full Scorpion System, that is for sale Separately at £130)
*All Engine Mounts with the Engine
The engine has 161,000 on it, although this shouldn't put you off. It doesn't skip a beat and runs beautifully.
It also has Magnecor 8mm Ignition Leads at no extra cost, these cost £80 alone.
I am more than happy to do a demo day so you can see that the engine works, I will post pictures shortly to show you the engine itself in the car.
Price is £320
Please PM me if interested
Thank you,
KP
Edited by KPARRIS-JONES
rivate phone number removed, Please use PM for contact
  • 9 months later...
C52 Gearbox still up for sale - £120 collected or £200 fitted.
KP
