Drivers Seat Removal
phil9843
Anyone know how to remove the drivers seat from a 2007RAV4 T180 The side of th eleather upholstery is torn/worn ---would Mr T cover this as a goodwill gesture If not is it difficut to remove
Thabk you
There is a warranty TSB for cracks in the leather. Don't take the seat out, see if a dealer will take it as a policy warranty. Even if they won't, taking the seat out is easy but the tricky part is securing the seat belt pre-tensioners. The connectors are special and need to be shorted with the installed shorting pins otherwise the pre-tensionors and maybe the seat side air bags will deploy.
Subject has been debated on numerous occasions.
Anchor man has given some good advice and i had my leather seat base replaaced under the warranty as this is a known "anomoly" regarding the drivers seat tear.
Here is a link to it.
http://www.toyotaownersclub.com/forums/index.php?showtopic=124142&st=0&p=1109514&hl=+drivers%20+seat&fromsearch=1entry1109514
