Black Plastic Pins
forevered
after taking the black plastic cover off to get to the bulbs to change ive noticed the little black plastic pins that hold it in place have become slack and pop out much to easily, and ive lost one that fell out does anyone know if theres a way of making them tight again and what are they called, and where can i buy them ? thanks for any help
I had to replace a couple on my previous Corolla - cannot remember how much they were (think something like 50p each). Take one into a Toyota dealer to use as an example and order some
You need to "trigger" the pins after removing them in order to make them work well again. I doubt you broke them after one removal.
Take the pin in your hand. Push the actual pin from the bottom so that it pops out. Now you have pin and the base separated. Push the base into the hole, and only after that insert the pin. Don't push it too hard, as it will get into "removal" position.
