Carina Ii Strut Brace
CarinaII
I was wondering if anyone knows where i can get a front strut brace for a 90' 1.6 GL Carina II?
I've see na picture one one with one on somewhere before, so i assume they're available.
Hallo my friend,i am a new member but i think i can help you.I was searching for a strut brace for my Carina E in CUSCO's site and i found a catalogue with strut braces for Toyotas..So i am not sure but as far as i understood from the model code cusco produces a strut brace for your car and it must be aluminium.Take a look at Cusco but use a translator such as Altavista to understand what's going on in there!Cusco also has an English version of its site but there aren't much to understand from it!So good luck!I hope i helped you! :hokus-pokus:
PS:Finally i installed a Sparco strut brace for my car because no other company produces for Carina E..It is made fron iron and it is adjustable..Not so good but it works fine!!Take care!Sorry for my english.. :ffs:
  • 2 months later...
If the toyota ones are 2 expensive, why not try a universal strut brace from ripspeed etc. They are centrally adjustable and should tighten things up no end. :thumbsup:
