Does anyone happen to know the new & minimum thickness of the brake discs on a 2006 2.2 D4D verso?
Mine's due in for a service soon & I'd like to measure them & know how much life is left in the brakes before I send it in.
On which subject has anyone ever experimented with different brake pads & managed to improve the braking performance on a Verso? In comparison to my last VW & my current BMW, the Verso's brakes seem to be made of soft cheese!
Don`t you have much trust in your garage Iain ? :)
Last main dealer that told me I needed to change my discs & pads urgently was wrong by , oh a mere 32,000 miles :rolleyes: :rolleyes::) (Not a Toyota dealer though). I've had two other instances of similar including a well known tyre shop who tried to tell me they weren't going to allow me to take my car until I'd paid them to change the front pads :censor: :censor: (which had about 5mm left on them, I usually change them at somewhere between 2 & 4mm)
Its also one of those jobs I'm happy to DIY & you can do so whilst still mainting a fully stamped service book :thumbsup:
Tyre and exhaust dealers were notorius for trying to ramp up work but a main dealer will/should base their replacement criteria on the mileage the vehicle will be expected to travel before they see it again so I can`t see a problem if you explain that if replacement is necessery you`d like to do the work yourself and they would amend the service history accordingly.
Found something that says the fronts are 26mm with a 2mm wear limit & the rears are 10mm with 1.5mm wear limit. Time to take the wheels off & get the micrometer out :thumbsup:
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
