Supra Mk3 1Jz-Gte 2.5L Ct15B W/ Turbocharger Genuine Brand New
Mistermena
Someone might find this of interest...
Toyota Chaser/Cresta/Mark II Tourer V (JZX81, JZX90, JZX100, JZX110)
- Toyota Soarer (JZZ30)
- Toyota Supra MK III (chassis code JZA70, Japan only)
- Toyota Verossa
- Toyota Crown (JZS170)
Description
By 1996, all JZ engines were now featuring Toyota's variable valve timing, VVT-i. Toyota made some other updates in 1996. 1JZ was now using a single CT 15B turbo for generating boost. Water jackets were modified for improved cylinder cooling and cam friction was reduced witha special coating. Compression ratio was also increased to 9.0:1. This reworked engine was called the third generation. Though there were no change in power output, the engine was more efficient and more responsive thanks to the increase in torque in lower RPMs.
Item Situation
Brand New
Net Weight
150kg
Source
Kinugawa Turbo
eBay Item number: 120796892598
How much!? :blink:
Thats a bit expensive if you ask me....
... then again i guess it is new...
How much!? :blink:
I recon if you can get it for £999 and pick it up its a bargin for new engine. If i had a car that it'll fit, I'd buy it for cheap money. :thumbsup:
Its located in Saga in Japan, so would need to Shell over £600 for delivery :(
Is it? I didn't see that bit when i posted it! But a £1600 its still something to think about for a new engine. Saw it on eBay and thought I'd give to heads up. :thumbsup:
£1600... plus import duty and VAT, so add about 30% or so...
Oh, you would then need to find a 1JZ-VVTi ECU. Hens teeth :D
Also, nit picking, the JZA-70 never recieved this engine as per the Ad :D
I know nothing about these engines at all. The post was put up as a "Just in case" someone needed one. :thumbsup:
Not having a go!!!
Just adding to Leeky's point..
The 1JZ is a great engine, some would argue better than the larger 2jz.
Not having a go!!!
No probs my mate.:thumbsup:
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
