Radio Code
pal1
Hi
I have a 06 d4d, if i disconnect the Battery will I need to put a code into the radio ? I don't have one if I do.
also, the gear nob metal has worn, how do I get it off.
mike
Radio not coded, Nigel, so disconnect with confidence. As for your worn out knob....golly gosh....what have you been doing?
Big Kev :toast:
A shiny modified Knob seen today in Scotlandshire ...
Mike is Your one the same as My one where You have to lift the collar before You are able to select reverse ??
Wee Charlie.
Hi
I have a 06 d4d, if i disconnect the battery will I need to put a code into the radio ? I don't have one if I do.
mike
Hi Charlie
Yes, what's left of the top is just like that.
Mike
Kev, got the wife to give it a 'good yank' and twist it back and forward but nothing is happening !! I maybe if I found a younger one, that might help .
Hi Charlie
Mike
Stroof, Dan....a younger knob...? Go for a 2009 SR180 then.....look what happened to Charlie's....covered in wee red bits....bad sign that.
:thumbsup:
Mike I was hoping maybe Yours was a simpler design to My one as I couldn't fathom out how to remove it when it got the red bits applied . Sorry cant therefore help ...
Sure Anchorman will be a bit more up on Knobs though !!................................................. :blink: :blink:
Wee Charlie.
Wee Charlie.
How to handle your knob ;)
Hi
My nob is like Charlie s, the top bit is worn through from too much resting of sweaty hand on it !! I need to take off the top bit. Oh dear.
Hi
Your hand or Your Danny ??................................................. :yahoo: :yahoo: :yahoo:
Wee Charlie.
