1.8 97 Avensis Misfire
lefrisp
I have a 1997 Avensis 1.8 petrol.
Good old car but has one annoying and I fear soon to become terminal issue.
I have had the car 2 years and it has always had a bit of a misfire but only when under High revs or when on a hill in too high a gear, i.e when the engine is under some kind of stress. Its always been a bit intermittent and doesn't always happen.
Lately it has started getting all sluggish and the misfire is occurring more and more often. It seems to occur most frequently when the engine is quite cold / just after startup.
First step is a new set of plugs just to rule that out as its a chap step to take.
Whats next? Ignition coils? are there any easy ways to diagnose the ignition coils?
Does this model have an ECU? how does that get tested.
Any quick fixes that you good peeps out there know about is this a regular fault?
In summary any help gratefully accepted.
I would go for the coils next. You should check their resistance to see if they are within tolerances (haynes manual would have these details)
You can get ecu readers off eBay for about 20 quid (i have one) but the sockets to plug them into were only standardised after 2001 so you may struggle there.
Forgot to add you might want to check the camshaft and crank sensors, should be about 20 quid each so reasonably cheap
service the car
Clean TPS
Cam and crankshaft sensors
replace sparkplugs and try..
if not it could be the ignitor or coilpacks.
to check coilpacks remove and inspect the connection and look for cracks
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
