Power Steering Bleed Valve Location?
ADAM121
can anyone help me locate the power steering bleed valve/nipple on my 1995 1.8st celica,i thought id found it before as im trying to solve my squeak when i turn my wheel full lock left and right,i heard i need to change the fluid as weve had the car a week and it looks like its never been done,i bought some lucas fluid today and heard this will stop the squeal,as i said i thought i found it before and bled it and came to drive tonight and the clutch was none existant,bled the wrong freakin valve,so i gotta top up both now,so ive lost my place now babbling on,oh yeah,the location of the bleed valve on my celica,thanks.
Bleed nipple? The system bleeds itself if you have air in the pipes.
If you wanna drain the system you're best off pulling the low pressure return pipe off the rack. Drains quick this way.
