Well, I have just replaced the bolt and nut that fell off the opening window on the sliding door. I had to replace it on my first previa, and now with my 1997 Previa the same nut and bolt dropped off. However, this time I learnt from the first car - if the window is loose then wind can catch the glass and force it open.... and leads to the glass smashing. So a quick tape up job, and a call to Parts king got me a replacement nut, bolt and rubber washer to secure the window properly. must be the most expensive nut and bolt I have ever bought but at least it avoids a window glass replacement !!
