Headlight/side Lights
L22KMD
Guys, when changing headlight/sidelight bulbs do you need to take plastic cover off that attaches to slam panel.if so hows it done,cheers......
The handbook advises that the upper part of the air cleaner duct may need removing to allow easy access to the left hand side bulbs. One push clip needs to be removed
ok,bulbs ordered,to replace bulbs is it a quareter turn or do the holders just pull out.cheers.
Headlight bulbs (high beam and low beam) are roughly a quarter turn counter clockwise. The connector disengages from the bulb by pressing a plastic lock release on the connector.
The side light bulb base turns counter clockwise on the passenger side, and clockwise on the drivers side. Once the bulb base and bulb are removed, the bulb then pulls out of the bulb base.
