Lift Kit On A Rav4.1
carlb84
hi guys, im new to the world of rav4's. i just got a 4 door 1998 vx been thinking of lifting it for better ground clearance. what is the general view on this and what have people done to their rav? i have found spacer kits on eBay with either 50mm or 25mm lift
http://www.ebay.co.uk/itm/Toyota-rav-4-lift-kit-50mm-aluminium-/330626830730?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cfae5118a#ht_500wt_1054
thanks in advance for any advice.
Hi carl new to the rav 4.1 myself having purchased a 2 door myself this summer. These would be good for off roading but i dont know about road use, might affect the handling and stability but i suppose you would need to talk to somebody has them fitted on here to know
Hi there
You can lift the Rav4....but only by 40mm !....on shocks & springs.
If you wish to use bigger wheels & tyres it is possible but be careful of full lock,tyres rubbing on wheel arch liners (especially if you have mud terrains) where is you get a large stone stuck in the treads it can do some real damage....not good.
Due it being a monocoque body ( i.e no live axles & no ladder chassis ,lifting is very limited)
Iron man do a lift kit,as do Old man emu....but these aint cheap.
There is a site.....
www.Rav4world.com
I believe someone there called Ravster has done all this...looks quite cool,but to only gain 70mm..max..not worth it really.
ravster4x4-2307-picture16864t-quad-tips.jpgravster4x4-2307-picture14278t-again-jerry-can.jpgravster4x4-2307-picture15322t-next-20l-jerry-can.jpgravster4x4-2307-picture15577t-next-400ml-spray-paint-can.jpgA few pics from his gallery..to give you an idea
I do some green laning in mine,but am real careful with big ruts & try only drive the easy ones in my area.....but they aint that easy,requires some interesting driving :thumbsup:
hello and welcome to the forum.
I'd tend to go down the route of fitting bigger wheels. I use 18" on both of mine just now with a wider wheel and tyre on RAV number 2 - which means the car straddles potholes !!
I've worked on the suspension of mine but tbh I don't think a lift kit will do much. Better to go for a larger wheel/tyre combo and gain some more width.
Hopefully I'll be posting up some more pics.... number 1 RAV is getting a full rollcage fitted just now.
Just to add - if you are buying alloys, then go to a specialist who can tell you what offset you need for the chosen wheel, - this to avoid the tyre scuffing the inner wing.
If you are serious, you could also go for adjustable shocks to be able to firm up the suspension. A cheap fix is to use the rubber inserts put in the coil springs - made for caravanners but stops the rear suspension bottoming out so easily.
i currently have 235/60/16 road tyres, gonna be fitting a set of falken land air t110's 235/60/16 i might try some of those rubber spring assisters
