1972 Rt 81 Camber Angle Settings.
Hi guys,am Eric in Kenya,East Africa and have been trying to get the correct camber angle settings on my Toyota RT 81 12R ENGINE car,the car always pulls to the right while driving. I have changed all the suspension parts ,checked the duo wishbone suspension arms which are ok.I din't manage to trace the problem,I have tried adjusting the camber angle by use of the camber shims but in vain,to add on the whole problem,the tires wear on the inner side even though computer readings read no fault when I check for wheel alignment and camber angle.
So I have questions on my mind; 1.What is the correct camber angle for the RT81?
2.Which is the standard size of the camber adjustment shims?
3.If I had to modify this type of suspension,which modern car would be compatible?(consider the brake callipers?
Anyone out there who can help me out can post ideas to me here or on my email address(ricshii@gmail.com or ejuliana@hotmail.com),I would greatly appreciate.
Thank you in advance.
Eric.
