Where Is The Fuse For 12V Cig Lighter
uzyg
Hi all,
Can you please tell me where the fuse is for the 12v cig lighter? Its no longer giving power so I am guessing the fuse needs replacing.
Does any one know the exact location or have a wiring diagram?
The car is a 57 plate 1.6 petrol Auris
Thanks.
Hello.
I'm from Russia and sorry for my English.
Fuse box is located here post-114306-0-29788500-1320222634_thumb. Look to the bottom, it is covered with a plastic cover on the latch
the fuse post-114306-0-29074900-1320222666_thumb.
Is the fuse located under the metal cover please?
Sorry. I'm not understood your question.
The fuse box is located behind your OBD plug. You have to get your head down low in order to see the fuse box. It also has a blue/white diagram sticker on it. It is not under the metal cover that is under the steering wheel.
em no...its no where near the obd2 port......go to the passenger footwell and look up as if you were looking up behind the clove box you will see a plastic trim...pull this out the way(pulls down and towards you)then look up you will see a much smaller plastic cover this pulls off then you will see the fuses on the back of the small cover you pulled off you will see what fuse is what on the reverse.....
