Camber Adjustment Bolts
davegooner7
my front wheel camber is off, i need more negitive camber. has any used those and where did you get them i was looking at those http://www.ebay.ie/itm/5-81270K-EIBACH-Front-Camber-Bolts-Toyota-Corolla-03-08-/180746007016?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a154d31e8 and was wondering if avensis T25 the same size.
thanks
dave
It may be worth investigating why the camber is wrong before trying to alter it. If a conponet of the suspensiion has been altered, worn damaged or bent you may be adressing the cause first.
just had an nct test same as mot test every thing ok
I didn't know they checked the camber during the MOT or ECT test as you say. Must take quite a bit of tine setting the laser kit and so forth.
Camber on the Avensis is adjusted by loosening the lower shock absorber bolts, moving the shock absorber in- or outwards, and replacing the bolts by camber adjustment bolts from the following table.
Quite a labour intensive job, even with advanced measuring equipment and all parts and tools ready...
Good luck
post-84513-0-36101300-1320269056_thumb.p
post-84513-0-48683800-1320269078_thumb.p
you dont check camber,caster or toe in these tests but depending on tyre wear you would recomend a wheel alighnment check...
but i agree with the above find out whats causing the issue first..
what i ment was they check suspension sorry about confusion
i do mots everyday but some things you cant see like a tiny bend can put the camber well out.. a bottom arm bolt thats shifted can put the camber out too mate..
In my above post I merely indicated how the adjustment should be done on the Avensis, instead of saying "You cannot use the Corolla-method bolts in the eBay link".
And if the adjustment is not done for "cosmetic reasons" :unsure: , then of course you should investigate the cause first.
