Changing The Dip Bulb
regentalcoing
Hello,
Forgive me for repeating another topic if it exists. I'm trying to change one of the dip bulbs on the passenger side. I can see how you get the main headlight bulb out, but as for the dip bulb all I can see is the power leads going to it, there's no o-ring or anything it's properly housed in behind the plastic. The haynes manual suggests jacking the car up, removing front bumper..... etc which is a bit of a ubik on. Any suggestions at all would be appreciated.
jack
The dipped headlight and main beam headlight are both operated through the same bulb..... The main headlight bulb does both....
I'm not sure what other bulb you're referring to but if its the dipped headlight that's not working, its the main bulb that needs changing (its "H4" type by the way)
