Charliefarlies Guide To Switching The Tpms Pink Wire
CharlieFarlie
Just to note:
Tyre pressure monitoring systems fitted to vehicles first registered after 1 January 2012 must be working correctly and not indicating a malfunction. From 20th March 2013 this will become a 'fail item' where any defects are found.
Benefit of an OEM unit . . . I Just remove it :D
  • 1 year later...
Thanks for the Post Charlie, Just few Question as I am new here just bought used 2006 T180 77K, cut the inside ring an tyre to make alloys normal - unfortunately didnt notice about Sensors neither me nor tyre fitter guy and they cut / broke the sensors as they said.
Bought New sensors from Euro car parts but Light still coming up not allowing me to use Cruise control.
Paid£100 to Charles clark Toyota to put sensor codes in monitor but useless today got another flashing tyre pressure light they said have to buy from Toyota £80 x 4 :(
I wonder if I do this "cut the pink wire etc " and put the switch - does it will fix my problem ?
Also Please assists as I am not good in wiring:
1 x Pink end ( clock side ) goes in the middle of the switch where the other end(TPMS) side goes ?
which wire goes to earth ?
Thank you alots
