Zorst
yaris t bone
my HKS zorst is orderd cant wait for it too come are they hard too fit <_<
Hi yaris t bone
No mate very easy to fit. All you need is a spanner some WD40 and a long flat screw driver and some exhaust paste and wire brush or sand paper :thumbsup:
Ist undo the bolt which is fitted to the bracket that is fitted to the exhaust spray a little WD40 over bolts to help turn it. This should come away easy.
2nd Then spray WD40 over the rubbers which hold the exhaust in place spray generously over the rubbers so that you can prise the old exhaust off using the long flat screw driver :thumbsup:
3rd clean off rust and dirt around the exhaust using wire brush or sand paper. apply some exhaust paste to the end of exhaust on the car to seal the new one. Again use generously covering the ends of the new exhaust and re fit the new exhaust :thumbsup:
4th Re fit new exhaust start up the car let it run for about 5 minutes and place a rag into exhaust blocking the bore and listen out if you can hear if there is a leak. If everything is done right it will be sealed good :thumbsup: If there is a slight leak just undo bracket and apply some more paste and re tighten the bracket a little. Not to tight as you will shear off the bolts.
There you go as easy as one two three :thumbsup: Then go out for a drive and enjoy the sound :P :D :lol:
jerry!!
the sound is a good, but with the centre section, still pretty quiet, but depends what ya want, witht he centre bit its kinda low key growling, more befy that standard, but if you replace the centre section with straight through, then its fannytastic!!!
