Wiring A Ee80 With A Fitted 5E
smiges
i have a 1988 ee80 dx corolla that's the front wheel drive one.i have under the hood a 5e-fhe engine with 4e-fte pistons, arp head bolts and valve springs,272degrees cams,adjustable cam gears,c150 manual transmission with lsd and a4:3 gear ratio kit,stage 2 pressure plate,solid hub copper clutch,a 10lbs slotted fly wheel,teflon engine mounts,4e-fe intake manufold,tdo4-l turbo, oil cooler, front mount intercooler,2 core radiator,a 2 bar map sensor, 4e-fte engine ecu with speed, boost, fuel and spark cuts taken out, msd blaster 3 coil, msd 6al II ignition,afc piggy back,ep91 engine harness,mazda injectors,boshe external fuel pump, 2,1/2 into 2,1/4 exhaust pipe,2,1/4 full flow dynomax exhaust,head port&polish,sequential blow off valve,1,3/4 screamer pipe,bull horn extractor,ae92 supercharger front & rear brakes, ep91 brake booster and master cylinder,front and rear coil tein coil overs,teflon bushings,front and rear upper and lower strut braces.but i'm having trouble getting it wired up. can some one please give me assistance
Hi Reco, sounds like a great project, I'm sure someone will be able to help you :thumbsup:
Welcome to TOC Reco.if you ask for advice on the corolla forum, i am sure you will get the help your after.
