Sat Nav Advice
yiqbal
Hi guys,
im new on here and would like some advice about a sat nav.
i have bought a double din sat nav for my auris and would like to know if it easy to install it in myself.
any help would be appreciated.
Sorry, I have no idea how to fit one, but if it was me looking to buy one, I would have found out how to fit it before buying it to make sure i had the right tools and was competent enough to manage the task.
I hope you find a guide and manage to fit it though.
i have found information on how to remove the trim and access the sat nav, i just really wanted any info on how people have gone about theirs.
i have got a quote from a professional fitter but i thought i might be able to do it myself and save myself some money.
Hi yiqbal,
Have you looked in Toyota tech?
If not try this: http://www.toyota-tech.eu
Select OWNER and then select Accessory Installation Manuals. You willthen have to fill in a document for the details of your car.
Good chance the Instructions will be there.
I wanted to remove my front bumper to change the horrible horn on this car. I found the instructions in the Installation Manual for the front and rear parking sensors.
So, if you do not find it immediately, you could look in other accessories installation instructions.
Good luck.
I really appreciate that mate,
thank you
it looks a bit daunting but hopefully should be able to do it
Bought a tns510 off ebay and installed it myself.
Downloaded the Toyota tech doc and it was very straightforward.
File attached
Regards
