Smokey Engine
paul.o
can sombody throw some light on this please???????????
i have a 2005 toyota avensis 2.2 d4d and have just had a reconditioned engine put in but when the garage started it up it filled the workshop up with smoke when they plug in their computer it does not put any faults up
I would expect a bit of smoke from a recon engine on first start up, but it should clear quickly, is it still smokey?
Kingo :thumbsup:
yes it's thick black smoke and the engine will only idle not rev the smoke compleatly fills up the workshop
Black smoke on a diesel engine is a sign of to much fuel or too little air.
Firts thing to check is the inlet system is connected up correctly with no obvious signs of blockages or leaks, etc.
I am with jamesbelfast on this, It could be a blocked intercooler or trapped/collapsed inlet hose causing overfueling,or pump timing wrong or worst case scenario fuel pump/injectors knackered. :crybaby:
Alfie B
Um, I'm almost too scared to ask this. Did the garage that fitted the engine supply it? If so its their problem to sort.
unfortunatly the garage did not supply the engine BUT i run a small taxi company and the garage do all the servicing on all the cars and trust them compleatly they have found a place that will check the injectors for £50 + VAT so that is my next port of call as they have triple checked thier work will keep everyone posted on the results
can i thank evryone for thier replys
hi mate
when you say "reconditioned" -- what do you mean? Have you a list of jobs performed or bill where the same listed jobs are in?
The idea is even though they have recon the engine but remained the same untouch injectors -- this might be the main problem.
It looks you have an overfueling or (!) late injection timing. Ask them to check with correct timing moment. It couldl be happened just in case they stripped the engine down and missed onetooth on timing gear etec. Cheers/Igor
i brought just the block all the rest was from old engine .the old engine was coked up so something caused the old one to seize injectors have been sent off for checking will have news in a couple of days
in case you have collected one motor from so many parts then it was a real risk to miss injection moment adjusting.
cheers/Igor
can i ask why you fitted a recon engine??what was wrong with it?if the engine has seized i wouldnt have used any of the old engine!!none of it.....also your car might have been covered under the toyota extended warranty but em its not now.....
JUST HAD INJECTORS BACK THEY ARE FINE . GARAGE IS GOING TO CHECK TIMING NOW
yes correct
I have also this kind of problem on my Toyota Hi Ace, How can you remove this black smoke that comes out?
the original engine seized the car has been sent to a diesel specialist now injectors fine timing looks ok
how did they check the timing?to check the timing correctly your ment to remove the engine......seized??lack of oil?headgasket?
