Mileage
edminson2012
can someone tell me how reliable toyota engines are ?? if a 2001 VVT-I Celica has done 117000 will it keep on going if its been looked after ??
thanks
The engines are good with plenty with a lot more miles on them than 117000.
The only issue you need to worry about is that it is a prefacelift engine. These all have a design flaw that caqn result in excessive oil useage. ALL the prefacelift engine have the flaw but NOT ALL develop the oil useage issue.
Regular servicing, oil checking & non thrashing of the engine all the time 'should' keep the oil issue from appearing.
thanks for that, is there anyway of spotting this when going to look at some??
Yeah, all the 140 VVT-i's that are 1999 (99) to 2002 (52) are affected. So go for a 2003 onwards if you have the funds.
Another easy spot, it the front bumper will have a long slit as a grile with the toyota Badge above it, inseatd of the Badge being in a small grile. Or the older cars have a grey interior, where as the newer have a dark interior.
Well the engines of Toyota are all pretty good,They just need to take care of them and be in condition every time.
