Cold Idle Engine Dies
Boris Kowalski
cold idle engine dies and must be kept joined the accelerator. after heat goes normal.
what is the solution of the problem?
It could be the glow plugs or a coolant temp sensor or a mutitude of other things. Have you got a fault code reader and had it read? You can buy one off eBay if you've not got one (As well as lots of other places) for a little as £12. They plug into a laptop and away you go. :thumbsup:
as visible yrs powered by vvt-i
check with MAF sensor + throttle to clean both
it is because of poor petrol/air mixture.
Cheers/Igor
Didn't see that it was a petrol model. But now can see that on the members details, so forget what I said about glow plugs as you haven't got any of them... :!Removed!:
