I have read a couple of articles lately which have me scratching my head.
Turbo light: I have a usual 2.2 TD 3CTE engine and drive it hard sometimes (burning off kids at the lights with their baseball cap on the wrong way round.) But I never get a light up on the dash telling me my turbo has kicked in????
Turbo timer: When fitted aparently these will run the engine for a few seconds after you've pulled the key out in case the turbo needs cooling. It never does this.
Is there any signs or sounds I should be witnessing that I actually have an operational turbo somewhere under my bum?
Ed.
err... id imagine you would have sod all power if its wasnt working mate.... low comp, running the tick black ooozie stuff, you really would be able to tell :D
You should be able to hear the turbo 'woosh' for want of a better word, mines an auto and if I push throttle to about 3/4 from a standstill the car moves forward in no big rush then you hear the turbo wind up and depending on the conditions I often get a wheel spinning (such a boy racer, wheres my furry dice), which means there must be something there to propel the 2 ton+ lump forward
  • 5 years later...
i drive a liteace 2ltr T/D and my turbo make a whistling noise when it kicks in.
