Starting Problems
aquamax
Hi can any one help me i have a Rav4 D-4D VX it has done 94000 miles it also has full service history i am having starting problems it start fine when cold it turns over well the problem starts when it gets hot if i drive for lets say 30 minutes turn the car off and try to start it it will just turn over after waiting 20 minutes or so it will start i have been told it could be the Battery but it turns over fine also been told it could be a temperature sensor but i just dont know what to do can any body help me Cheers sorry forgot to say it is a 2002
Hi can any one help me i have a Rav4 D-4D VX it has done 94000 miles it also has full service history i am having starting problems it start fine when cold it turns over well the problem starts when it gets hot if i drive for lets say 30 minutes turn the car off and try to start it it will just turn over after waiting 20 minutes or so it will start i have been told it could be the battery but it turns over fine also been told it could be a temperature sensor but i just dont know what to do can any body help me Cheers sorry forgot to say it is a 2002
hello
SCV seems to play with you.
cheers/igor
hello
cheers/igor
SCV what is that and where is it on the car
Cheers/aquamax
Is it possible you have mis-fueled.
I had same symtoms when I had half a tank of diesel and filed up with petrol.
Stupid but it happens
If it won't turn when its hot you need to do a cranking test with the starter. It sounds like the windings are getting goosed. Try bump starting it when hot on a hill.
Hi no i have not mis-fueled
Cheers Aquamax
Hi thanks for reply the car turns over fine but will not start when hot the more you try the Battery start to give up but thats normal as i said if you leave it for a while it will start fine i just dont know
Cheers Aquamax
I wonder if its starved of fuel and the temp is a red herring. Change the fuel filter and try again.
Can you bump start diesels? I`ve never had the honour :D
