Yaris Boot Light Problems
Juleskahuna
My yaris 2006 boot interior light has gone. Replaced the bulb but still not working. Anyone know which fuse controls this? The fuse box detail is far from helpful.
Any help would be most appreciated can't see a thing in there with the winter nights!
HI
I 'm guessing from a Mark1 Yaris wiring diagram which shows no boot light ! (And mine has one).
Try the rear fog light. If it does not work, then it could be that fuse..Which on the Mark1 is Passenger compartment fusebox ECU-B 7.5amp.
I had same thing with boot light dealer had a look at service and said its the boot door lock that needs replacing, I have decided to live without the boot light for now.assuming they are in the know the lock must contain the switch for the boot light.
